1999 Cadillac Catera Engine Oil Cooler
DJENNINGSSR
Engine Cooling problem
1999 Cadillac Catera 6 cyl Two Wheel Drive
Is it necessary to remove the cylinder heads in order to replace the oil cooler?
Jul 27, 2009 at 10:09 AM
FACTORYJACK
  • 4,159 POSTS
Not necessary, after upper and lower intake are removed, you need to remove the large nuts that fasten the cooler to the cover. remove the cover bolts, and remove the cooler in two pieces(cover, and cooler).
Jul 27, 2009 at 3:21 PM
