1999 Cadillac Catera crankshaft position sensor
1999 CADILLAC CATERA
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
DISISJC
  • 18 POSTS
Is there a thread on steps to replace the cps?
Jan 26, 2008 at 11:42 AM
BLACKOP555
  • 10,386 POSTS
Not that i know of, i always suggest people take it in on the ground sof it has to be relearnt afterwords and youd end up towing it in to the dealership.
Jan 26, 2008 at 1:07 PM
DISISJC
  • 18 POSTS
[quote:6c1286e73e="blackop555"]Not that i know of, i always suggest people take it in on the ground sof it has to be relearnt afterwords and youd end up towing it in to the dealership.[/quote:6c1286e73e]
Beings as how it won't run over a few minutes now, its either tow it now or tow it later then. So might as well try to install the cps and save that amount from the dealer I guess.
Jan 27, 2008 at 9:45 AM
BLACKOP555
  • 10,386 POSTS
you sure its the cps that is bad?
Jan 27, 2008 at 10:47 AM
BMRFIXIT
  • 19,053 POSTS
Crank sensor is at the left rear of the engine
https://images.2carpros.com/forum/automotive_pictures/99387_cadi_3.jpg
check if you have fuel pressure check the codes if possible
Jan 27, 2008 at 11:30 AM
DISISJC
  • 18 POSTS
No not entirely sure its the cps but symptoms point toward it.
Have no way of checking fuel pressure and codes. Car won't run long enough to get to Auto Zone to check codes. Have ordered and received the new cps so am going to install anyway. Thanks for your replys.
Jan 28, 2008 at 1:06 AM
BMRFIXIT
  • 19,053 POSTS
[quote:2182a29c2b="disisjc"]No not entirely sure its the cps but symptoms point toward it.
Have no way of checking fuel pressure and codes. Car won't run long enough to get to Auto Zone to check codes. Have ordered and received the new cps so am going to install anyway. Thanks for your replys.[/quote:2182a29c2b]
code reader for OBDII should be cheep enough
try ebay or other sites you can get it for $30 and up
it will become very helpful
Jan 28, 2008 at 8:33 AM
