Loosing radiator fluid
1998 CADILLAC CATERA
JESSICAS8918
Smells problem Automatic 86000 miles
I have to put antifreeze in my car like every 2 months and i don't see it leaking out of my car anywhere....but you can smell it burning.....what could be the problem?
Mar 26, 2008 at 3:34 AM
BUZZSAW
  • 1,198 POSTS
Your heater control valve, its behind the intake, close to the firewall, usually when this leaks it leaks a lot, it drips on the trans. other places is the oil cooler gasket leaks 2 ways, oil in the coolant (bad oil cooler), or leaks down the back on to the transmission like the heater control valve, since it is small leak I would ck the gasket to the oil cooler, this is under the intake( the bottom one) remove the plenum (top Intake) to see the bottom intake. if your going to take it off do not over tighten the bottom intake its plastic you will crack it.
https://youtu.be/W8kra65m15c
here is a video to test the system
Mar 26, 2008 at 11:44 AM
