Engine misfire
107,358 MILES • 6 CYL • FWD • AUTOMATIC
BADDDUDE4U
We are working on a 1998 Catera that we removed the heads on to replace leaking head gaskets. When we put it back together we had amechanic come out from Cadillac to set up the timing belt. At that time he checked the cam gears and made sure that the cams were in the right location. The intake cams were coded with a "G" and the exhaust cams were coded with an "A." The cam gears were properly installed with the timing marks used at 1,2,3 and 4 from passenger side to drivers side while looking towards engine from harmonic balancer. The engine lacks power, backfires through the intake, sets codes P0302, P0304, and P0306 all at the same time. One time it even set a code P0336 whick is a crank sensor code. We have checked the spark on cylinders 2, 4 and 6. Spark seems fine. We have removed the plugs and 1,3 and 5 are firing fine. Plugs 2, 4 and 6 seem to be wet. We have checked all the connections and found them to be OK. We are missing something and we cannot figure it out. We also had the man back from Cadillac and he is also stumped. Please help
Feb 28, 2008 at 10:41 AM
2CARPRO JACK
  • 11,533 POSTS
Do a full compression test to compare the odd # side of the engine to the even # side. All your misses are on one side of the engine.Sounds like low compression/valve timing issues.
Feb 28, 2008 at 11:36 PM
BUZZSAW
  • 1,198 POSTS
[quote:3a7cdc5893="BaddDude4U"]Engine Performance problem
1998 Cadillac Catera 6 cyl Front Wheel Drive Automatic 107358 miles
We are working on a 1998 Catera that we removed the heads on to replace leaking head gaskets. When we put it back together we had amechanic come out from Cadillac to set up the timing belt. At that time he checked the cam gears and made sure that the cams were in the right location. The intake cams were coded with a "G" and the exhaust cams were coded with an "A." The cam gears were properly installed with the timing marks used at 1,2,3 and 4 from passenger side to drivers side while looking towards engine from harmonic balancer. The engine lacks power, backfires through the intake, sets codes P0302, P0304, and P0306 all at the same time. One time it even set a code P0336 whick is a crank sensor code. We have checked the spark on cylinders 2, 4 and 6. Spark seems fine. We have removed the plugs and 1,3 and 5 are firing fine. Plugs 2, 4 and 6 seem to be wet. We have checked all the connections and found them to be OK. We are missing something and we cannot figure it out. We also had the man back from Cadillac and he is also stumped. Please help[/quote:3a7cdc5893]
did he use the timming belt tools to set up the t-belt? what made you think the head gaskets where bad? when you had the heads off did you check the valves for seating leaks? switch the plug wires around put evens on the odds and see if the misfires change to the odd side. is there oil in the spark plug tubes?
Mar 5, 2008 at 12:11 AM
