How do I replace the thermostat?
1997 CADILLAC CATERA
112,000 MILES • 6 CYL • 2WD • AUTOMATIC
KEN BURRIS
How do I replace the thermostat.Thank you,Ken Burris
Oct 3, 2008 at 6:25 AM
  • 110,244 POSTS
Ken: Just follow the upper rad hose toward the engine and you'll come to the t-stat housing. Drain the radiator, remove the upper hose, remove the housing and you'll see the t-stat. Reverse the sequence to replace it. I up loaded a picture of the housing for you. I hope it helps.
https://images.2carpros.com/forum/automotive_pictures/249084_Graphic_3.jpg
If you have any other questions, let me know. Joe
Nov 17, 2008 at 2:57 PM
