1997 Cadillac Catera OIL PUMP
ANIMALLL
Engine Mechanical problem
1997 Cadillac Catera 6 cyl Two Wheel Drive Automatic
i just replaced my engine with a used engine can not get any oil pressure was told the oil pump lost its prime and i have to prime the pump but i don't know how to do this can you help me
Oct 6, 2009 at 9:37 AM
FACTORYJACK
  • 4,159 POSTS
How are you determining that you have no oil pressure, By the gauge on the vehicle? Is the engine noisy? Losing prime is not very common, and the fact that it is a used engine, you don't know the history. Pull the oil pressure sender out of the front and start it to see if it truly does not flow. There is no procedure for priming, there was a pre-luber issued to dealers in around 2002, that was specifically called for when installing a new, remanufactured, or serviced(anytime crank or conn-rods were removed) engine.
Oct 9, 2009 at 4:19 PM
