1997 Cadillac Catera Interior lights problem
1997 CADILLAC CATERA
INSTALLIT4U
Hi, I installed an aftermarket stereo using the Metra Bose interface module and it works great. My problem is after the install the interior lights are not working properly. The customer says sometimes they do sometimes they don't. Then today he called and said the light flickered after he turned the car off.
Is it possible something is loose? A schematic would be great. I am a mobile electronics installer with 10+ years of experience in the field and a degree electronic technology. Any help is greatly appreciated. Thanks
Mar 3, 2009 at 12:32 AM
2CARPRO JACK
  • 11,533 POSTS
So I assume it is the Bose system in the car? Looks like the Green/Yellow wire in slot E5 of theoriginal plug is for illumination signal.Try eliminating that wire just to see if it is what is interfering.I will include thediagram, if you cannot read it then send back your email and I will send it that way
https://images.2carpros.com/forum/automotive_pictures/1639_caddy_catera_1.jpg
Mar 5, 2009 at 11:36 PM
ERNESTO NILO
buenas tardes yo tengo un problema similar le agradeceria me pudiera enviar este diagrama ya que no se visualiza good afternoon I have a similar problem I would appreciate if you could send me this diagram as it is not displayed
Jun 14, 2019 at 5:50 AM
