How do you change ignition switch
CADY1997
  • 1997 CADILLAC CATERA
How do you change ignition switch and do you have a diagram for it?
Wednesday, December 2nd, 2009 AT 7:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL:
Disconnect the negative battery cable.
Remove the steering wheel.
Remove the inflatable restraint steering wheel module coil.
Remove the ignition switch set screw.
Turn the ignition switch to the ON position.
Insert a small flat bladed tool into the ignition switch connector hole in order to depress the locking tab.
Pull the connector from the ignition switch.
Remove ignition switch.
SET SCREW
https://www.2carpros.com/forum/automotive_pictures/261618_0900c1528025f0a3_1.jpg
REMOVING SWITCH
https://www.2carpros.com/forum/automotive_pictures/261618_2_70.jpg
INSTALLATION:
Install the ignition switch onto the lock cylinder housing.
Attach the electrical connector to the ignition switch.
Install the set screw until fully seated and not stripped.
Install the inflatable restraint steering wheel module coil.
Wednesday, April 21st, 2021 AT 12:43 PM
