1997 Cadillac Catera
1997 CADILLAC CATERA
77,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAMIENWARLOCK
The driver side heater blows cold air but the passenger side works fine. A noise is heard behind the radio console when the car is shut off. It's 15 here I need heat.
Mar 9, 2008 at 1:41 AM
BUZZSAW
  • 1,198 POSTS
[quote:a33e36d80e="damienwarlock"]Heater problem
1997 Cadillac Catera 6 cyl Two Wheel Drive Automatic 77000 miles
The driver side heater blows cold air but the passenger side works fine. A noise is heard behind the radio console when the car is shut off. It's 15 here I need heat.[/quote:a33e36d80e]
is there a coolant leak? if not ck the heater control valve it behind the the intake by the firewall. ck the vaccume tube to it if its not broken replace the valve. if the valve is leaking coolant will be all over the transmittion, its orange in color
Mar 10, 2008 at 5:52 AM
