1996 Cadillac Brougham check engine light and pass key faul
107,000 MILES • V8 • 2WD • AUTOMATIC
KJAKE
The car is running fine, but when I turn the ignition the pass key fault light comes on (and then goes off) and the check engine light stays on. Any ideas?
Feb 15, 2009 at 4:58 AM
FACTORYJACK
  • 4,159 POSTS
It would need some further diagnosis. I doubt the two are related. The pass key fault, most often ends up being some broken wires at the ignition cylinder that provide the key resistance value to the pass key module. That don't bring a check engine light though.
Feb 16, 2009 at 1:45 PM
