1992 Cadillac Brougham with or without engine oil cooler
125,000 MILES • V8 • 2WD • AUTOMATIC
ADRENALINEMX
Two different radiators are available for this car----either with or without engine oil cooler. My rad. has only two small lines (on the passenger side) as well as the lower main hose fitting and the upper main hose fitting on the drivers side. If the car has an 'engine oil cooler' wouldn't it have two more lines ON the radiator???--In other words- how can I tell if I have an 'engine oil cooler'???
Jan 11, 2008 at 10:32 AM
  • 110,248 POSTS
Hi:
The two small lines are trans cooler lines. An engine cooler would be a small verision of the rad. They are usually mounted in front of the rad.
Nov 17, 2008 at 1:59 PM
