1989 Cadillac Brougham Stalling when it starts
OZ_PRATT
Engine Performance problem
1989 Cadillac Brougham V8 Two Wheel Drive Automatic
I have a 89 cadillac brougham and as soon as i start it, it stalls out i used carburetor cleaner and a adjusted the carburetor screw. what can i do to fix this?
Apr 13, 2008 at 8:13 AM
  • 110,248 POSTS
Hi:
The problem may not be the carb. Are you seeing any smoke coming from the exhaust? Also, check for vacuum leaks. For some reason I'm starting to see problems with the brake booster or boster vacuum hose. Check it out.
Nov 17, 2008 at 1:50 PM
