1989 Cadillac Brougham
1989 CADILLAC FLEETWOOD BROUGHAM
SIDESHOWBOB8300
Electrical problem
1989 Cadillac Brougham V8 Two Wheel Drive Automatic
I have replaced the ignition switch and the starter selonoid tests good. When I turn the key to accessory everything works great. Heater fan, radio, lights, all electric accessories run. As soon as I turn the key to start position everything goes dead and the battery is completely drained. What would you suggest I try next. I can't see an obviously broken wire.
Oct 20, 2008 at 5:29 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Hi:
IS it that nothing works or the battery immediately goes dead? Make sure the starter wires are not touching.
Nov 17, 2008 at 8:26 PM
SIDESHOWBOB8300
The battery goes completely dead when the ignition is turned to start. It will start when jumped by an already running car. Then will run fine until shut off. Turn ign. to acc. and batt. has full charge. Dead when you hit start. I got under the dash and flicked the key several times and didn't see or hear anything unusual. Working on it alone so I can't check outside and turn the key at the same time by myself. Just looking for some advice on what to try next.
Nov 18, 2008 at 12:57 AM
