1988 Cadillac Brougham rear axle align
200,000 MILES • V8 • 2WD • AUTOMATIC
JOE STEPHEN
Rear end replaced due to accident. Frame may not be true/plum. Need to perform post align on rear-end install.
Category or degree of repair difficulty info requested.
May 4, 2008 at 4:29 AM
BUZZSAW
  • 1,198 POSTS
[quote:d097459f0e="Joe Stephen"]Drive Train Axles Bearings problem
1988 Cadillac Brougham V8 Two Wheel Drive Automatic 200000 miles
Category or degree of repair difficulty info requested.[/quote:d097459f0e]
its not hard, but its not easy either, if you dont have a lift use jack stands not cylinder blocks please put the new rear end in and then an alignment, if it is bent then a frame shop is required
May 5, 2008 at 10:10 AM
