Cadaletic converter
150,000 MILES • 6 CYL • FWD • AUTOMATIC
AMENA
Is it necessary to use an original cadaletic converter when replacing the part? I found an aluminum one for 120.00 and mechanic suggests we need a 600.00 original. WHAT Is THE Difference?
Jan 19, 2016 at 12:49 PM
JOHNNYT73
  • 924 POSTS
In older vehicles you could get away with because they only had one oxygen sensor before the cat to monitor combustion. With newer cars they are a lot more precise. I would suggest going with the OEM replacement to be absolutely sure that it fixes the issue.
Jan 19, 2016 at 9:46 PM
