Cabin Air Flow
120,000 MILES
PEU78
Does the cabin air filter, filter the air flow whether the vehicle's air flow is on recirc or bringing in air from outside of the vehicle
Aug 21, 2018 at 2:30 PM
  • 110,248 POSTS
Yes, it is designed to keep dust from entering the cabin regardless of fresh air mode door.
Here are the directions for replacing it in case you need them:
_________________________________________
PROCEDURES
Dust and Pollen Filter Replacement
The dust and pollen filter should be replaced every 30,000 miles (48,000 km) or 24 months whichever comes first Replace the filter more often if the airflow is less than usual
1. Remove the glove box.
2. Cut the plastic cross brace in the glove box opening with diagonal cutters in the area shown, and discard it.
3. Remove the bolts, the screws and the glove box frame.
4. Remove the filter lid (A) from the evaporator, then pull out the dust and pollen filter (B).
5. Install the filter in the reverse order of removal. Make sure that there is no air leaking out of the evaporator.
6. Install the glove box frame and glove box in the reverse order of removal.
The following pictures correlate with the aforementioned directions.
Aug 22, 2018 at 10:21 AM
