cabin air filter
44,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
ST3
This is and SLT version. Does it have a cabin air filter and if so how do I change the cabin air filter?
Nov 29, 2016 at 9:09 PM
HMAC300
  • 48,601 POSTS
our manual does not show cabin filters , auto parts sell them even though manufacturers do not put them in. they did for a while but stopped.
Nov 29, 2016 at 11:22 PM
ST3
Thanks. The dealer's service manger who knows me read off the screen that it was due. Some of the simple things I do so I went to their parts counter to order one. That took two tries and then he sent me to the local Chevrolet dealer with their wholesale price on the card as it was in stock. I then started to try and find out how to install it and I cannot find anything on how to on this year truck, years before or newer models are there and I have seen some comments that my truck does not have one. I appreciate your quick response. Any suggestion on where to get OEM parts (like an engine air filter) online? Thanks again.
Nov 30, 2016 at 1:31 AM
HMAC300
  • 48,601 POSTS
gmpartsdirect.com for OE parts they ship to your house cheaper than a dealer.
Nov 30, 2016 at 4:12 AM
ST3
Thank you for your help. After going to the dealer today for an oil and filter change, I am told that all 2013 GMC Sierra 1500's have cabin air filters- none. Whatever GM's calculus is, my fan is just wide open to particulates. I was told though that I could have the service tech (or I could do it which is way above my pay grade) cut out a plastic section of the blower frame component and put in my own filter along with a separate bracket to hold it. I was advised to not have this done or for me to do it. My question to the service advisor was what else was left off of my truck to save money that could be installed later at additional expense? I did not expect nor got an answer on that. I'd just rather buy the filters and replace them as needed and prolong the fans life but that's just me. Thank you very much for your help. I took my cabin air filter back to the other dealer across the street and exchanged it for an air filter for the motor which I KNOW i'll need!
Dec 1, 2016 at 12:50 AM
HMAC300
  • 48,601 POSTS
well they never used cabin filters for years and it has no effect on the motor one way or another just to keep big particles of dust and leaves out if they get in there . they should have never started then quit doing this. if you went to gmparts direct.com and looked they may have the kit available which probably includes instructions if you are intent on doing it. There are plenty of competent mechanics in local garages that do just as good of work as dealers and don't charge as high.
Dec 1, 2016 at 4:11 AM
MAJOSHANGELA
How do I change the cabin air filter? Everything I have seen says to undo one screw & I'll be able to get to it but I can't figure out how to get into the housing to get the filter out. Thank you
Apr 30, 2019 at 10:47 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
your vehicle doesn't have a cabin filter, they discontinued that in 2003 for the sierra...
JGREINBOLD
Does my 2001 Sierra 2500 HD truck have a cabin air filter, where would I find it, and how would I go about changing it?
KHLOW2008
  • 41,812 POSTS
Yes there is one.
CABIN AIR FILTER
Removal
NOTE: Numbers in parenthesis refer to numbers in figures.
1. Remove the instrument panel sound insulator from under right side of instrument panel. See Fig. 1. Remove the retaining bolts. Remove the insulator (1) from the HVAC module by pulling downwards.
2. Remove the filter access door screw. Remove the filter access door (1) from the HVAC module. Remove both passenger compartment air filters (2). See Fig. 2.
Installation
1. Install the both passenger compartment air filters (2). Install the filter access door (1) to the HVAC module.
2. Install the filter access door screw and tighten to 14 INCH lbs. (1.6 N.m). Install the instrument panel sound insulator.
ICORALXXX
does a 2005 GMC Yukon have a cabin air filter?
Dec 17, 2019 at 7:54 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny
No, there is no cabin air filter in your truck. I've attached an article below.Thanks for using 2CarPros.
Dec 17, 2019 at 3:46 PM
