The Engine management light on?
119,000 MILES • 2.2L • 4 CYL • TURBO • 2WD • AUTOMATIC
SAMUEL1903
The car is slow to change gears, RPM is higher than it should be, and the engine light is on.
Sep 10, 2023 at 7:30 PM
  • 55,694 POSTS
Yes, this sounds like the front SAM control unit is out, but we should do a CAN scan to see what codes are stored. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is how to change the SAM controller out and I have included the transmission wiring diagrams so you can see how the system works. You can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know what happens.
Sep 11, 2023 at 11:26 AM
