How to reset code C13AF?
31,287 MILES • 4 CYL • 2WD • AUTOMATIC
NAIM UDDIN JEWEL
Fault Code C13AF.
Jun 22, 2022 at 7:37 PM
  • 55,766 POSTS
Is the parking brake warning light on? This code is set when the car is in motion with the parking brake on, which means the parking brake actuator is not working. When the parking brake is set, can you start the car (turn it on) and put it in gear to see if you can hear the parking brake actuators working on both sides? If you can only hear one side the side, you can't hear needs to be replaced which I have included in the diagrams below. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
Jun 24, 2022 at 1:56 AM
