C121C, P0016, car in limp mode.
135,000 MILES • 5.7L • V8 • AWD • AUTOMATIC
FOOLSCROW
Codes C121C, P0016
Check engine light and ESP (traction control) light come on and car goes into limp mode.
Replaced egr valve with a new gasket on the tube, no vac leak, was a problem.
Replaced camshaft sensor.
Cleared codes
After about 10 minutes lights come on and loss of acceleration i.e. Limp mode.
Nov 25, 2015 at 6:01 AM
  • 55,851 POSTS
Hi FoolsCrow,
If a code P0016 is present it can cause the C121C which is request for torque denied. P0016 is camshaft/cranshft correlation problem which can be caused by a defective crankshaft angle sensor CKS, check out this guide which gives you the idea on how to change yours,
your is located here:
Nov 26, 2015 at 12:56 AM
THIS IS MIKE
  • 686 POSTS
Make sure to follow up with your expert so he can help you.
Nov 30, 2015 at 3:55 AM
