Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Nissan
Rogue
Drivetrain
Transfer Case
Wiring
Code C1210, where is the AWD module located?
2008 NISSAN ROGUE
200,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
EARL91
MEMBER
Need a location of the AWD module and a CAN-bus wiring diagram for this code please.
May 22, 2024 at 4:13 AM
Experienced Mechanic
The code could be related to a few different things including the ABS module, AWD module, ECM, and so on.
If you look below, I attached the diagnostics for the code and the last two pics are the can-bus circuits.
Take a look and let me know if this helps.
joe
Images (Click to enlarge)
May 23, 2024 at 11:09 AM
Add image or video
Ask a new question
Engine won't start
Air Conditioner — Not Working
