Engine lost power while driving
2003 MINI COOPER S
138,000 MILES • 4 CYL • TURBO • MANUAL
ERIK LANDIS
my vehicle lost power and would only go 30 MPH. i hooked up my code reader and it showed these codes ssf20381, 1237 pressure sensor intake manifold before compressor input low...
0130 oxygen sensor bank 1 before cat, malfunction.
c110+ code reader.
Apr 3, 2021 at 2:35 AM
  • 110,241 POSTS
This could be related to the manifold absolute pressure sensor (MAP). Let's start by checking it. First, check the connector and wiring at the sensor. I attached a pic below to help you locate it. The code indicates a low voltage issue. That could be the result of corrosion in the plug.
See pic below.
Apr 6, 2021 at 1:20 PM
