Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Pontiac
Torrent
Climate Control
Air Conditioner
Compressor
Bypass
Bypass the A/C compressor?
2006 PONTIAC TORRENT
158,000 MILES • 3.4L • V6 • AUTOMATIC
ROBERTM1970
MEMBER
What size belt would i need to bypass the A/C compressor with a smaller belt and without a bypass pulley?
Oct 19, 2022 at 10:11 PM
BORIS K
Experienced Mechanic
To bypass the A/C compressor, you should be able to use a 643K6 or 645K6 belt.
See image below from a 2005 Chevrolet Equinox, same engine. follow the blue line.
To access the belt, you will need to remove the engine mounting, see image 2.
Hope this helps.
Cheers, Boris
Images (Click to enlarge)
Oct 21, 2022 at 1:46 AM
ROBERTM1970
MEMBER
Thank you, i really appreciate it.
Oct 21, 2022 at 1:24 PM
Add image or video
Ask a new question
Engine overheating
Engine won't start
