Bypass c305 connector
180,000 MILES
KIPP_1992
  • 18 POSTS
I had a lot of water leakage into the c305 connector pins were corroded Nd snapped off. van had been having a few issues and some told me to check the c305 connector. so I did. I was told I could bypass the connector but do not know which wires connect to which from inside van that was in the c305 connector and ones coming from the 3 wiring harnesses that connected to the c305.
Feb 11, 2020 at 11:09 AM
Good evening,
That connector was a very bad design. I have done many of them.
You can buy the connector for a little money but you have to pin it.
I attached the diagram. I circled the wires that go through that connector. It is for the fuel pump, sender and the fuel pressure sensor.
Feb 11, 2020 at 12:45 PM
KIPP_1992
  • 18 POSTS
What are the pink wires? all wires were pulled out of c305 connector there are two pink wires and only one connector coming from under van has a pink wire. there's also a light blue wire.
Feb 11, 2020 at 12:51 PM
KIPP_1992
  • 18 POSTS
I would like to bypass the connector if I could and just hard wire it I have looked all over for the connector . just want to know what wires would attach to what.
Feb 11, 2020 at 12:54 PM
I understand.
Can you post some pictures of the wires? The diagram does not show pink wires.
Feb 11, 2020 at 3:17 PM
KIPP_1992
  • 18 POSTS
Yes, when I get home I will.
Feb 11, 2020 at 8:01 PM
Feb 11, 2020 at 8:39 PM
KIPP_1992
  • 18 POSTS
How do I post photos?
Feb 11, 2020 at 9:51 PM
KIPP_1992
  • 18 POSTS
That's the wires on inside.
Feb 11, 2020 at 10:14 PM
What about the other side of the connector? Can you show me that as well?
Feb 12, 2020 at 12:31 AM
KIPP_1992
  • 18 POSTS
Other side of which connector?
Feb 12, 2020 at 12:37 AM
KIPP_1992
  • 18 POSTS
This?
Feb 12, 2020 at 12:39 AM
I need to see the wires you are connecting too.
Feb 12, 2020 at 12:43 AM
KIPP_1992
  • 18 POSTS
And the other plug has 4 wires coming out and 1 blue wire that was in a plug of its own.
Feb 12, 2020 at 12:52 AM
That is good.
You can start by matching up the colors of the wires in that connector to the loose wires.
Start matching up the wires and see if they all are accounted for.
Roy.
Feb 12, 2020 at 1:05 AM
KIPP_1992
  • 18 POSTS
All except on the inside of van there is two wires that don't match up with any on connectors. so I don't know where they connect an extra pink and I think white.
Feb 12, 2020 at 1:09 AM
Those wires are for the vent solenoid on the fuel tank.
Feb 12, 2020 at 1:14 AM
KIPP_1992
  • 18 POSTS
There was one plug with 4 wires black red white and brown then one with 8 wires and the third little plug only had a light blue wire in it. I'm confused here.
Feb 12, 2020 at 1:18 AM
You just said all the wires match up except the pink and white.
Can you explain?
Feb 12, 2020 at 1:22 AM
KIPP_1992
  • 18 POSTS
There's two extra in the van than what's coming from the connectors one pink one goes to the big connector under the van, but the other pink one doesn't match up with another wire coming from either connector and I think there is a white on two that doesn't match up to another wire.
Feb 12, 2020 at 1:33 AM
KIPP_1992
  • 18 POSTS
If you look at my first photo I posted there is two pink wires.
Feb 12, 2020 at 1:34 AM
Okay, let us back up.
Match up the ones that match. Take a picture of the remaining ones and let me know. I need to see both the harness inside and outside as well. Tape the wires together, for now, to see what does not match.
Feb 12, 2020 at 1:37 AM
KIPP_1992
  • 18 POSTS
Okay, will do that when I get home and get back to you.
Feb 12, 2020 at 1:44 AM
Sounds like a plan.
Feb 12, 2020 at 2:04 AM
KIPP_1992
  • 18 POSTS
The pink and black ones have no wire to connect to on other connectors,
Feb 12, 2020 at 6:17 AM
KIPP_1992
  • 18 POSTS
All other wires match up with another except those two.
Feb 12, 2020 at 6:21 AM
Good.
Those 2 are for the solenoid I told you about. They go to the vent solenoid.
There should be a 2 wire connector to attach those wires.
Feb 12, 2020 at 6:26 AM
KIPP_1992
  • 18 POSTS
There's only the connector that had 8 wires the connector that had 4 and a connector with one single wire that is light blue. there is no 2 wire connector .
Feb 12, 2020 at 6:30 AM
Okay, go to the solenoid. I posted the picture back a few posts. Those wires need to be run to that solenoid.
Feb 12, 2020 at 6:36 AM
KIPP_1992
  • 18 POSTS
There's no wires going from solenoid to where that connector is located and no that I took the connectors off. I have TCS light on and ABS light.
Feb 12, 2020 at 6:45 AM
If you have an ohmmeter, ohm the wires from the solenoid to the loose wires and see if you have continuity.
Feb 12, 2020 at 7:22 AM
