Bypass A/C
1997 BUICK SKYLARK
87,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RODNEY WALDROP
Can you bypass the AC on this car?
Mar 23, 2019 at 10:09 AM
  • 110,240 POSTS
Welcome to 2CarPros.
Yes, it can be done. What I recommend is removing the compressor and replacing it with an AC bypass pulley. That way you have the same belt routing and the same belt can be used. The part is about the same cost as a new belt and eliminates the issues with routing.
I believe the part you need is manufactured by Dorman and the part number is 34236. Please confirm that is the correct one at the parts store when you go to get it. I attached a picture of it.
Mar 23, 2019 at 2:36 PM
RODNEY WALDROP
Thank you you were very helpful.
Mar 23, 2019 at 2:42 PM
  • 110,240 POSTS
Happy to help. Let me know if you have other questions. Also, please confirm that part number is for your vehicle when you ask.
Mar 23, 2019 at 4:10 PM
