By passing the ac pulley for shorter belt
1999 LINCOLN TOWN CAR
178,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
RYNESA78
Trying to bypass the AC pulley on this the power steering told the serpentine belt and do you have to unhook the compressor if you don't want to pull it at work
Dec 29, 2025 at 6:53 AM
STEVE W.
  • 15,292 POSTS
With the belt routing on that engine it is not possible to bypass the AC using just a belt, you need to use a bypass pulley in place of the compressor. Might I ask why you want to bypass the AC?
Dec 29, 2025 at 9:29 AM
