Buzzing noise from gas tank door?
75,000 MILES • 4 CYL • 2WD • AUTOMATIC
PANPEEKER
Just started hearing a loud, one-second long buzzing sound from the gas tank access door when I open the doors with the key fob, or when the auto-lock feature activates shortly after starting to drive. Is this something that indicates a possible serious problem or can I ignore it? Thanks in advance for any help!
Oct 1, 2025 at 2:44 AM
BLACKOP555
  • 10,386 POSTS
Sounds like a failing lock actuator. Any door not lock and unlock normally? Lock and unlock several times does noise stop and one lock quit functioning?
Oct 1, 2025 at 12:10 PM
