Burns real rich
1993 OLDSMOBILE 88
78,700 MILES • 0.6L • 6 CYL • 2WD • AUTOMATIC
STEVEN PITCOX
My exhausts really has a strong smell, but the smoke from the exhaust pipe leaves a black residue on snow. after running a while pipe raddles. so we believed it was the catalytic converter was bad so we took it off. It ran alright for a bit stared raddling again. still black smoke. bought 02 sensor, after installing it what should I do if problem continues?
Dec 3, 2017 at 11:52 AM
  • 31,937 POSTS
Condensation from the engine when cold is normal, and you will see water coming from the exhaust. i would be looking at tune items first and a scan for any underlying fault codes, not all codes will set a check light, also a live data read on a scanner will show if the O2 sensors are working by the voltage they are generating. check these first.
Dec 3, 2017 at 3:09 PM
