Burning smell with check battery and engine light
714,580 MILES • 2.7L • 6 CYL • 4WD • AUTOMATIC
RMORLEY76
Our vehicle has had an intermittent problem with a burning smell with no smoke. The battery and brake light comes on at the same time. It seems to happen when it is wet. Like after a big rain fall or recently we had a large snow melt leaving good sized puddles. It does not seem to happen until we drive for a bit. We have noticed an issue with the anti-lock brakes locking at times causing us to pump the brakes. We have also noticed that the headlights seem to be dimmer and the wipers are slower. We had not noticed the smell for quite a while. I think the last time was in the summer, after driving through a large puddle? Then yesterday after a really mild day for January and after driving through some large puddles from snow melt. I have read some other people's issues online and have not found anything that is a definite match. The closest idea I have seen is a issue with the alternator. If anyone has any suggestions what this might be?
Jan 12, 2018 at 11:02 AM
HARRY P
  • 2,292 POSTS
Sounds like a battery or alternator problem. First, take a look at the alternator belt and see if it is cracked and worn looking. Here is a guide for that: https://www.2carpros.com/articles/how-a-serpentine-belt-works
If the belt checks out okay, then take the car to the local auto parts place and have them run a check on the alternator. I will bet that their computer tells you that either your alternator or battery is failing.
Do that and let us know what you come up with. We will go from there.
Jan 12, 2018 at 11:19 AM
