Burning smell & whining sound with brake & battery lights on
115,000 MILES
CHERRY4CALIF
  • 9 POSTS
We just recently replaced the alternator; one of the belts has recently been replaced. Now there's a whining sound as soon as you start the car & there's a burning sound. The only lights that came on when this started was the brake and battery light. The smell starts as soon as you start the car & gets worse if driven. All the belts look to be working properly. There's about 117,000 miles on the car.
Oct 31, 2013 at 2:43 AM
  • 110,246 POSTS
If the battery light is on, the new alt may not be good. Remove it and have it bench tested at a local parts store.
Let me know what you find.
Oct 31, 2013 at 3:43 AM
CHERRY4CALIF
  • 9 POSTS
What about the burning smell & the whining? We've never had the before with the bad alternator.
Oct 31, 2013 at 3:51 AM
  • 110,246 POSTS
I'm thinking that the smell and sound may be coming from the new alt. After running the vehicle, check to see if that seems to be where the smell is coming from.
Oct 31, 2013 at 4:00 AM
CHERRY4CALIF
  • 9 POSTS
We've been driving it without a problem for about 2 months since replacing the alternator. We'll check. You're pretty sure that would be it?
Oct 31, 2013 at 5:05 AM
CHERRY4CALIF
  • 9 POSTS
What are the symptoms of a bad pulley that needs to be replaced?
Oct 31, 2013 at 5:24 AM
  • 110,246 POSTS
I can't be 100% sure, but since the battery light is on, I would think there is a problem in that area. As far as the pulley, it matters what the pulley is doing. If it is locking up, it can cause the belt to squeal and overheat. If you haven't. remove the belt and check all belt driven pulleys to see if there are any that make noise or have a drag when you turn them.
Oct 31, 2013 at 9:26 AM
CHERRY4CALIF
  • 9 POSTS
Thank you so much! We'll get the alternator checked. The belts seem to be working fine!
Oct 31, 2013 at 10:03 AM
  • 110,246 POSTS
Oct 31, 2013 at 10:07 AM
CHERRY4CALIF
  • 9 POSTS
My husband disconnected the battery & we haven't had an issue for almost a week.
Nov 4, 2013 at 12:07 AM
  • 110,246 POSTS
Disconnected the battery? Is this something he does every night? Are the battery and brake lights still on?
Nov 4, 2013 at 12:38 AM
CHERRY4CALIF
  • 9 POSTS
No. He did it to see if it would help. The lights went off & haven't come back on & there's no smell. It's running normally so far.
Nov 4, 2013 at 1:55 AM
  • 110,246 POSTS
Let me know if it starts up again or if you have other questions.
Nov 4, 2013 at 11:46 AM
