The car feels bumpy  on the hard roads
2013 SUZUKI WAGON
20,000 MILES • 4 CYL • MANUAL
SANDEEPS
  • 27 POSTS
I have Maruthi Eritga 2013 car. We changed the shock absorbers for the rear one both left and right with new one but that does not make much difference, now we also feel the front feel bumpier than the rear one now. Car is having all 4 new tires and pressure set to 30 it's a nitrogen. Wheel alignment is also checked. Please let me know if there is something to change/check. And the rear shock absorbers are changed with Monroe shock absorbers.
Feb 8, 2021 at 12:04 AM
  • 110,241 POSTS
When you replace only the rear, often times it makes the front feel worse or bad. Were they ever replaced?
https://www.2carpros.com/articles/replace-shock-absorber
Feb 8, 2021 at 9:15 AM
SANDEEPS
  • 27 POSTS
No the front shock absorbers were never replaced. It came with the manufacturer during the time of purchase in 2013. However car ran only close to 20,000 miles. So replacing the front shock absorbers fix this issue? Or is there anything to check beneath the car body?
Thanks
Feb 8, 2021 at 4:33 PM
  • 110,241 POSTS
Based on your description, it sounds like the front shocks, but not being there makes it difficult for me to determine. If you bounce the front of the vehicle, does the bouncing stop within 3 bounces when you stop?
Feb 9, 2021 at 10:41 AM
SANDEEPS
  • 27 POSTS
Yes, the front bouncing stops with in 3 seconds.
Feb 9, 2021 at 11:30 AM
  • 110,241 POSTS
Does it stop within 3 bounces?
Feb 10, 2021 at 5:28 AM
SANDEEPS
  • 27 POSTS
Yes it does.
Feb 10, 2021 at 9:11 AM
  • 110,241 POSTS
Then the shocks are still okay. I do have one more question. Has the shop checked the steering components? Things such as ball joints, tie rods, and so on can make it feel loose.
Also, is there any noise associated with the issue?
Feb 10, 2021 at 10:48 AM
SANDEEPS
  • 27 POSTS
Not sure about it. I will ask them to check. Does it require disassembly?
Feb 10, 2021 at 12:26 PM
SANDEEPS
  • 27 POSTS
And one more thing; the rear shock absorbers are replaced with monroe shock absorbers. The front shock absorbers are directly from OEM. will that make difference with brands?
Feb 10, 2021 at 2:14 PM
SANDEEPS
  • 27 POSTS
The culprit is shock absorbers itself. Shocks became hard. Mechanic replaced whole front suspension system. Car is running smoothly now.
Feb 11, 2021 at 2:51 AM
  • 110,241 POSTS
Was it the new shocks or the front original ones on the front? Regardless, I'm glad to hear it's fixed. Please feel free to come back anytime in the future if you have questions.
Take care of yourself,
Feb 11, 2021 at 10:37 AM
SANDEEPS
  • 27 POSTS
Sure thanks . Yes, those are replaced with brand new one with Monroe brand. Honestly outside they name it as oem brand Suzuki but inside on the shock absorber it mentioned as Monroe. So technically even the old OEM shock absorber is from Monroe.
Feb 11, 2021 at 11:16 AM
  • 110,241 POSTS
Yep, the manufacturers have large companies simply put their name on the part. It doesn't surprise me they were Monroe. They are very common.
You take care of yourself and come back anytime.
Feb 11, 2021 at 11:20 AM
