rear wiper does not work
2006 BUICK TERRAZA
BOGAS_56
Six cylinder two wheel drive automatic 60,000 miles
My rear wiper quit, and the front wipers still work fine. Is there a relay to the rear wiper motor? The fifteen amp fuse in the instrument panel is new and rear wiper still does not work. Or could it be the motor?
Mar 19, 2010 at 2:47 AM
GMTECH
  • 537 POSTS
I would say your rear wiper is definitely fried. I would replace it.You can always tell by a corrosion buildup around the wiper motor shaft. Also testing the power and ground at the motor is a good way to check. But the motor is a very common failure in these vehicles.
Oct 31, 2010 at 2:03 PM
ANONYMOUS
  • 0 POST
back wiper does not work.
Dec 27, 2016 at 7:19 AM (Merged)
HMAC300
  • 48,601 POSTS
check fuses and relay fuse three and relay twenty nine under dash.
