2006 Buick Terraza Both Rear wheel bearings and left Front
24,400 MILES • 6 CYL • 2WD • AUTOMATIC
DAVID L SWINDLER
Three subject wheel bearings have excessive play indicating that the pre-loading has failed. The disassembly of the real hubs appear straignt forward. When reassembling what locktight should be used to lock the hub bolts in place. Should new GM bolts with pre installed locktight patch be use? Should they be reassembled without locktight? Are there any other assembly precautions to be observed that are not obvous?
Jun 6, 2008 at 2:12 PM
DENNYP
  • 1,824 POSTS
GM recommends new bolts with the loctite on them. You can get by with just using red loctite on them.
Jun 30, 2008 at 12:24 PM
