2005 Buick Terraza power sliding doors
TUNDISH
Electrical problem
2005 Buick Terraza
When i open the drivers side rear power door once it is open it keeps trying to open then wont close . then if i put it in manual to close it when i put the van in drive the chime rings the entire time.
Jul 7, 2010 at 1:34 AM
GMTECH
  • 537 POSTS
Make sure the contact pad and plungers are clean. They can be cleaned with a scotch brite pad. You may need a door adjustment and need to relearn the door position in the module. A number of things can affect the operation, if it binds in anyway the motor will detect it and may not operate properly.
Oct 31, 2010 at 1:34 PM
