2005 Buick Terraza L F Blinker bulb
FF41998
Electrical problem
2005 Buick Terraza 6 cyl Front Wheel Drive Automatic
How to you change the front blinker bulbs on the Terraza
Oct 13, 2009 at 10:14 AM
GMTECH
  • 537 POSTS
All you need to do is remove the headlamp. Remove the 2 screws on the top to the rad support. Use a prybar and twist to pop the ball socket where it mounts near the fender. Then you have access to the signal bulb below.
Oct 31, 2010 at 2:07 PM
