2005 Buick Terraza electrical problems
12,800 MILES • 6 CYL • AWD • AUTOMATIC
CBM2005
The rear power vent windows (both left and right) and the rear wiper motor have stopped working at the same time. What can I check for the problem? There does not seem to be a fuse or rrelay listed in either fuse panel/power distribution center for either of these devices. Is the a harness connector that controls both that could have come loose, or a power relay associated with borh?
Jun 7, 2010 at 1:59 PM
GMTECH
  • 537 POSTS
More than likely it is a coincidence that all the motors have failed at the same time. It is common that the rear wiper will fail. I would replace that. The 2 side motors are common to fail as well but I would check power and ground at all the motors just to be sure.
Oct 31, 2010 at 1:39 PM
