2005 Buick Terraza Drivers side electric seat not moving
71,000 MILES • 6 CYL • FWD • AUTOMATIC
BOBBY GIBSON
I own a 2005 Buick Terazza, the drivers side electric seat will not obey any of the switches on the seat itself nor will it respond to the preset buttons on the drivers side door for the two drivers. I have replaced the two circuit breakers in the interior fuse block this did not help. There is no sound from the motors themseleves. I do get intermitten results when I take the circuit breakers out and then replace them. Is there any other electrical fuses or breakers or anything I can check.
Oct 28, 2009 at 7:52 AM
GMTECH
  • 537 POSTS
I would try checking the power and ground from the switch to the motor. And see if the switch has power and ground.
Nov 1, 2010 at 2:44 PM
