2005 Buick Terraza Changing the oil
2005 BUICK TERRAZA
76,000 MILES • 6 CYL • FWD • AUTOMATIC
JOBIVINS30
Can you tell me where exactly is the oil pan located so that I can remove the oil pain nut to drain the oil? I have looked at the pictures and video on your website and still am clueless. Thanks!
Nov 23, 2008 at 12:18 PM
  • 31,937 POSTS
HI there ,
The sump or oil pan is the bottom most portion of the engine, (not the transmission) there will be a drain plug at the bottom, undo this and drain the oil, do this with the oil warm as this will help remove more oil from the engine.
mark (mhpautos)
Nov 23, 2008 at 7:07 PM
