1994 Buick Skylark Cold Start Stalls
TONYTODD
1994 buick skylark 4 cyl.
All major ignition components have been replaced
In warmer days it started fine now in single digit temps , it will fire for a second, stall. to start after that involves several attempts with the peddle depressed partialy. run stall over and over. finaly start and hold peddle a minute, after a noticable change in engine, it runs fine.untill it sits over night.Also fuel filter changed, injecters cleaned, with the machine, not gas additive.Also if related on ocasion severe hesitation, studder off the line. Thanks very much.
Feb 10, 2007 at 3:15 AM
CHEVY22
  • 1,375 POSTS
hmm ,
i would start off by checking the fuel pressure , and watch the gauge to see if the pressure drops quickly ,if you get a pressure drop this would most likely be a failed fuel pressure regulator , but check the pressure and lets go from there
jim
Feb 17, 2007 at 7:32 AM
Suggested Repair
Check fuel pressure and watch whether it drops quickly. A rapid drop most likely indicates a failed fuel pressure regulator; continue diagnosis from the pressure test results.
Conversation Summary
The owner of a 1994 Buick Skylark reports cold-start stalling in single-digit temperatures after replacing major ignition parts, changing the fuel filter, and machine-cleaning the injectors. The engine fires briefly, stalls, and needs repeated attempts with the pedal partly depressed before it runs normally until it sits overnight. Occasional severe hesitation off the line was also reported. The expert recommends checking fuel pressure for a quick drop, which would most likely indicate a failed fuel pressure regulator.
