1998 Buick Skylark tension arm to loosen belt
1998 BUICK SKYLARK
40,000 MILES • 4 CYL • FWD • AUTOMATIC
BRICARELL
Where can I see a diagram to tell me where the tension arm is so I can replace an alternator?
thanks for the help.
Oct 17, 2009 at 1:43 AM
HMAC300
  • 48,601 POSTS
there should be one on the header on the front under the hood. If not check your car book if you have one. If neither of these check at the auto parts store when you pick up the alternator. They may have one.
Oct 31, 2009 at 10:21 AM
