1998 Buick Skylark power window
120,000 MILES • 6 CYL • FWD • AUTOMATIC
U54395
Drivers side window has not worked for years. Friend put the motor and the plastic thing with it on.
That was the problem appeared as rolled down a few times and then quit. He thinks it is in the switch now. All the other windows work do you get just that switch or all of them? I also read something about resetting the switch. It makes no noise like it is not making connection or something. When he first put it in it worked then I tried it and it didn't and he hit on the door and it worked. Any suggestions.
Thanks
Aug 16, 2010 at 10:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
could be loose or dirty connectors at the switch. if wiring is good than switch will probably need replaced.
Aug 17, 2010 at 11:44 AM
