1997 Buick Skylark Wheel Cylinder
106,000 MILES • 4 CYL • FWD • AUTOMATIC
DANIELRS57
I am trying to replace the wheel cylinder in my 97 skylark. after getting it all taken apart and unbolted i find that there is no room to remove the wheel cylinder. i was able to force the old one out but cant get the new one in. any ideas???[img:e690995e07]http://www.2carpros.com/forum/automotive_pictures/164310_030208_0725_1.jpg[/img:e690995e07]
Mar 1, 2008 at 11:30 PM
MASTERTECHTIM
  • 4,750 POSTS
this is normal. you need to remove the 3 torx screws(or atleast loosen them up) and actually pull the hub back a little bit to gain access. it is very easy and it should come right apart. there is one hole in the hub that will access the torx bolt, just keep moving that one hole to access all the torx bolts. hope this helps
Mar 1, 2008 at 11:40 PM
