1997 buick skylark water pump?
TRINATRINA
my car started smoking
i pulled over and let it sit
antifreeze all over the street
is it the water pump
what could it be
thanks for any help
Sep 2, 2006 at 4:32 PM
CATHY14
  • 14 POSTS
Generally, my experience with water pumps has been that when they go bad that's it and you won't be able to drive anywhere. If you were able to drive after that incident then I would say no it is not your water pump. Also, the water pump will make a noise if it is going bad. Maybe you just need to tighten the hoses.
Nov 11, 2006 at 3:32 AM
