Inside Water Leak
TRUE-TECH-TESTING
  • 5 POSTS
Electrical problem
1997 Buick Skylark 6 cyl Front Wheel Drive Automatic 100 k miles
I've got a leak in my car..when it rains.. weather its sitting or driving. water leaks in the front of it...
and fills up the drivers side...anyone have this problem??? and if so.
DO YOU HAVE ANY IDEA WHERE ITS LEAKING???
I've replaced the windshield.
Oct 18, 2008 at 1:40 AM
MERLIN2021
  • 17,250 POSTS
This is the TSB for leaks....
WATER LEAKING INTO PASSENGER COMPARTMENT - SEAL VENT
TECHNICAL SERVICE BULLETIN
Reference Number(s): 73-10-68 Related Ref Number(s): 73-10-68
ARTICLE BEGINNING
WATER LEAKING INTO PASSENGER COMPARTMENT (APPLY RTV SILICONE SEALER TO TOP VENT GRILLE ASSEMBLY)
Model(s): 1996-98 Buick Skylark
1996-98 Oldsmobile Achieva
1996-98 Pontiac Grand Am Section: 10 - Body Bulletin No.: 73-10-68 Date: April, 1998
CONDITION
Some owners may comment on water leaking into the passenger front floor area.
CAUSE
Condition may be due to poor adhesion of the top vent grille assembly to the windshield. The existing seal tape can separate from the glass or the grill above the A/C air intake canister and allow water to overflow into the passenger front floor area.
CORRECTION
Remove the top vent grille assembly. Clean the grille assembly and the surface of contact on the windshield of all sealing tape and adhesive residue. Apply a bead of RTV Clear Silicone Sealer from 3M(R), Part #08662, or equivalent, to the underside of the top vent grille assembly where the old seal tape was removed. Reinstall the grille. Wipe excess RTV Sealer horizontally across sealing area to achieve a smooth finish.
Oct 18, 2008 at 5:52 AM
TRUE-TECH-TESTING
  • 5 POSTS
[quote:7761a63063="merlin2021"]This is the TSB for leaks....
Page 1 of 1 WATER LEAKING INTO PASSENGER COMPARTMENT - SEAL VENT -1997 Buic...
ARTICLE BEGINNING
CONDITION
CAUSE
CORRECTION
WARRANTY INFORMATION
For vehicles repaired under warranty, use:
WARRANTY INFORMATION Labor Op Description Labor Time D1353 Panel, Cowl Vent Grille - Reseal (complete) 0.8 hr
© 2007 Mitchell Repair Information Co., LLC.
http://www.ondemand5.com/mric/common/asp/printart.aspx
10/18/2008[/quote:7761a63063]
the problem is drivers side not passanger side
it would be great to get fixed that easy if its a problem like that
Oct 18, 2008 at 9:12 AM
MERLIN2021
  • 17,250 POSTS
The problem with water is it follows the path of least resistance, and my have found a path to the drivers side, can happen....
Oct 18, 2008 at 12:40 PM
TRUE-TECH-TESTING
  • 5 POSTS
thanks Merlin!
any easy way to search for the culprit?
Oct 18, 2008 at 1:49 PM
MERLIN2021
  • 17,250 POSTS
Only way is the hose and an assistant, a good strong lamp will help the inside man...
Oct 18, 2008 at 2:09 PM
TRUE-TECH-TESTING
  • 5 POSTS
thank you so much merlin! you been a great help!
Oct 18, 2008 at 3:17 PM
MERLIN2021
  • 17,250 POSTS
Your welcome.
Oct 19, 2008 at 12:03 AM
