1997 Buick Skylark starter
1997 BUICK SKYLARK
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
DMAYER
car will turn over but wont start, new starter & battery
Jan 30, 2010 at 5:45 PM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Jan 30, 2010 at 6:08 PM
