1997 Buick Skylark intermittent start problem
70,000 MILES • 4 CYL • FWD • AUTOMATIC
BYRDDD
Often the idiot lights do not come on when the ignition is turned on, the engine will crank but not start. After 4 or 5 tries the idiot lights do come on, the engine cranks and starts. It happens every day and seems not to be affected by temp.
Feb 11, 2009 at 5:22 AM
JDL
  • 16,098 POSTS
You may have to check the feed to and from the ignition switch? You may have to check ground circuits also. Are the battery cables/wires clean and tight on both ends?
Feb 11, 2009 at 5:28 AM
