1997 Buick Skylark HEATER HOSE
125,000 MILES • 4 CYL • 2WD • AUTOMATIC
ISENABUG
HEATER HOSE SEEMS TO HAVE BROKEN OFF DOWN ON LOWER FIREWALL. IT SEEMS LIKE THERE IS SOME TYPE OF PLASTIC CONNECTOR OR SOMETHING ON THE HOSE COMING OUT OF THE FIREWALL. i'M GUESSING WHERE IT GOES THROUGH THE FIREWALL AND INTO THE HEATER CORE. THAT IS WHAT SEEMS TO HAVE BROKE. I LOST ALL MY COOLANT. HOW DO I REPAIR THIS, HOW HARD IS IT, AND IS THERE A NAME FOR THE CONNECTOR I AM SPEAKING OF? IS IT POSSIBLE TO REPLACE JUST THAT CONNECTOR AND ATTACH NEW HOSE UNDER HOOD, WITHOUT HAVING TO GET INSIDE THE FIREWALL INTERIOR? I HOPE I AM MAKING SENSE. I WOULD APPRECIATE YOUR INPUT ON THIS.
Jul 23, 2008 at 11:55 PM
JOHN18
  • 5 POSTS
The fitting is molded to the heater core(original equipment) and doesnt seem to be replaceable.The core would have to be replaced.
The fittings can be cut off carefully because the heater core has plastic end tanks and the fittings on these tanks are plastic.
The fittings make the heater core have two hose sizes and once the fittings are removed,the hose sizes are the same,or should be.This is true of some V-6 models.
The core can be bypassed on some cars,this is probably one of them.It is a hard job because of the location of the heater hose but it should be easier on a 4 cyl.
Aug 10, 2008 at 5:02 PM
