1997 Buick Skylark EGT Light on Dash
1997 BUICK SKYLARK
93,000 MILES • 4 CYL • 2WD • AUTOMATIC
STEIG
  • 5 POSTS
EGT light and Check engine light comes on. What causes this?
Mar 26, 2009 at 8:45 AM
EUGENE123
  • 273 POSTS
a check engine light comes on because the computer senses a change in temp or pressure or etc. an electrical problem a sensor usually when this is deteced the check engine light comes on
Mar 26, 2009 at 9:12 AM
STEIG
  • 5 POSTS
So what is the EGT trouble light on the dash telling me? What is the EGT?
Mar 26, 2009 at 10:03 AM
EUGENE123
  • 273 POSTS
exhaust gas temp light, this means that a sensor is not reading the right temp which could mean the sensor is bad
Mar 26, 2009 at 10:11 AM
STEIG
  • 5 POSTS
where is the EGT sensor found?
Mar 26, 2009 at 10:21 AM
STEIG
  • 5 POSTS
I am sorry, it is the ETS light that I need info on
Mar 26, 2009 at 1:12 PM
EUGENE123
  • 273 POSTS
that is the engine temp sensor do you also need to know where this located?
Mar 26, 2009 at 3:20 PM
STEIG
  • 5 POSTS
Yes........Thank You
Mar 26, 2009 at 10:58 PM
EUGENE123
  • 273 POSTS
Under hood, driver side, upper engine area, mounted in end of cylinder head
Mar 27, 2009 at 2:41 AM
