Access To Alternator Charging Posts
148,000 MILES • 6 CYL • FWD • AUTOMATIC
P4KILLER_
I am trying to upgrade my alternators existing charging and ground wires.
The alternator has a black cooling shroud on the back covering the posts i need to access.
The shroud seems removable, but the rear mounting bar is directly behind the shroud effectively blocking removale of the shroud.
I dont think removing the rear mounting bar (1 of 3 mounting bars) while the alt belt is under tension is a good idea.
So I believe i need release tension on the belt and remove the alternator to gain accsess to the posts.
Or can I just pop the shroud off....?
I think I know what needs to be done, but a step by step guide would be very much appreciated.
Pictures are supplied
Please help
Thanks Very much
P4Killer
[img:498127a8b0]http://www.2carpros.com/forum/automotive_pictures/527748_20100311_143426_1.jpg[/img:498127a8b0]
[img:498127a8b0]http://www.2carpros.com/forum/automotive_pictures/527748_20100311_143405_1.jpg[/img:498127a8b0]
May 15, 2010 at 7:38 AM
SATURNTECH9
  • 30,869 POSTS
.what model skylark do you have and ill get you the information you need.
May 17, 2010 at 11:17 AM
P4KILLER_
its a 1997 skylark gran sport 3.1 v6
also i figured it out, but if a may ask a different question instead
i was reinstalling the alternator,
the cooling shroud wouldnt fit properly
i realized the shroud has a tab that secures to the underside of the alternator
i was attempting to pop the tab into the correct position with my screwdriver
my screwdriver slipped and i slipped and shorted the alternator charging post against the engine block
sparks flew
i should add that the negative battery terminal was DISCONNECTED the entire time.
i had to leave for work so, i reinstalled the alternator
i checked the voltage at the front battery while the car was running and the voltage read 14.2v which should be normal
is it possible i didnt damage the alternator?
how can i test it?
i have a very high power audio system installed and the voltage meter in the car reads normal 14.5- 14.2v while driving
i played my system at full tilt, and experienced normal voltage drop
is my alt ok did i get lucky, or am i in trouble?
May 17, 2010 at 4:06 PM
SATURNTECH9
  • 30,869 POSTS
To test the alternator you can start the car let it idle turn your head lights on high beams on turn on your a/c on and see what your voltage is.let me know what your voltage is sounds like your ok though.
May 17, 2010 at 5:09 PM
P4KILLER_
will do first thing in the morning, thanks for the prompt reply
May 17, 2010 at 5:28 PM
P4KILLER_
well, with the car running at about 1k rpms
parked in the drive,
lights n high beams on
a/c on
stereo up a little bit, my voltage in car reads 14.6 back at the amplifier
voltage at front battery under the hood read 14.6
i took the alternator out and am running it up to autozone right now
what do you think?
May 18, 2010 at 2:46 AM
CHPITMAN
Electrical problem
1995 Buick Skylark 4 cyl Two Wheel Drive Automatic
How do you remove the alternator for replacement ?
Apr 26, 2019 at 11:00 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL: Disconnect the negative battery cable. Label and disengage the electrical connections from the alternator. On the 2.5L engines, loosen the adjusting bolts and remove the alternator belt. If equipped with a serpentine belt, loosen the tensioner and turn it counterclockwise to remove the belt. Unfasten the alternator mounting bolts, then detach the alternator air inlet connector (3.1L engine only) and remove the alternator from the engine. INSTALLATION: Fasten the alternator to the mounting bracket, using the retaining bolts, washers and nuts. Tighten the retainers to the specifications listed in the accompanying figures.
https://images.2carpros.com/forum/automotive_pictures/261618_0900c1528025f525_1.jpg
If equipped with the 3.1L engine, attach the alternator air inlet connector. Install the serpentine or alternator belt, as applicable. For details, please refer to of this information. Engage the alternator electrical connections. Tighten the "Bat" terminal nut to 65 inch lbs. (7 Nm). Check the belt tension, then adjust if necessary. Connect the negative battery cable, then check the alternator for proper operation.
