1997 Buick Skylark 97 WITH MULTIPLE PROBLEMS @ ONCE
47,000 MILES • 6 CYL • FWD • AUTOMATIC
97LARK
I WAS DRIVING ABOUT A WEEK AGO IN THE RAIN AND MY ABS LIGHT AND BRAKE LIGHT CAME ON. THE NEXT MORNING WHE I STARTED THE CAR THE LIGHTS WERE STILL ON AND I COULD NOT GET THE CAR OUT OF PARK. I USED THE BTSI AND BYPASSED IT BUT NOW MY AC COMPRESSOR WILL OT RUN, THE COOLING FAN WILL NOT RUN, THE CAR HAS NO POWER WHEN TAKING OFF. I SCANNED THE COMPUTER AND GOT MULTIPLE PROBLEMS. I CHECKED ALL FUSES AND ALL ARE GOOD I HAVE NO IDEA WHAT TO DO, THESE PROBLEMS ALL OCCURED AT THE SAME TIME.
Sep 16, 2009 at 1:06 AM
HMAC300
  • 48,601 POSTS
check for a bad battery/charging system problem. If the battery is no good then it screws up the computer system.
Oct 31, 2009 at 10:36 AM
85VET
i have the same car 97 6cy fwd and i had all those problems i checked the fuses went to a tranny shop and they (of course) wanted to rebuild it if u get like 9 diff codes on scan u should check in the engine bay theres a separate fuse box form the main one, the small fuse in the middle on the farthest (could be 20) might have blown it controls the abs the valves for emissions and ac the the trans shifting and the tcc brake switch, hope thats it 1.45 cost if it is
Jan 31, 2010 at 9:44 AM
